Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: would i be right to assume the omega '53 movement ring is made from Iron?
    Senior Member foilguy's Avatar
    UK
    4,484
    Default would i be right to assume the omega '53 movement ring is made from Iron?
    Will likely have to make it from scratch on the lathe. Anyone that has the specs let me know. I can obviously work off the movement case and dust cover, but all the same.
    Whoops looks like i found the answer from Smithswatches
    http://www.ebay.co.uk/gds/OMEGA-53-M...8427040/g.html
    1,702
    It may be mu-metal. Which is an iron alloy. I can make accurate measurements if you need. I was planning on maybe turning some myself, but I have a few other tool making projects on at the moment which take priority. As I mentioned before, I think there could be a possibility of 3D printing them in metal.
    UK
    4,484
    I thought that, until i saw the picture Dave linked to in another thread. I'm guessing MU metal isn't available in bar stock. 3D sintering seems to go against the mould, so to speak.
    7,272
    I can't find a copy of DEF-3 at the moment Paul only images of speedos..
    however the movement ring may be mu-metal rather than iron.
    here's some FA inspiration -
    1,702
    Mu metal is used extensively for anti-magnetic applications. It's often seen used for shielding electrical transformers (to stop the EMI interference). It could be formed, but this reduces its effectiveness as the grain structure of the metal is important. It's usually in the shape of a can / tube when used for transformers, so I guess it could be ordered in tubular sections.
    Member
    Mar 2014
    NZ
    263
    Quote Originally Posted by dave View Post
    Can’t see no FA
    Senior Member papazulu's Avatar
    Aug 2009
    Global
    1,377
    Don't talk to me about naval tradition. It's nothing but rum, sodomy and the lash.
    Sir Winston Churchill
    UK
    4,484
    Got that cover. Guess I'll have to use iron bar. Not that I'm bothered about the Faraday cage, but in effect, it should still work as one.
    UK
    4,484
    Thanks Dave. 🙂
  10. #10
    7,272
    Quote Originally Posted by Hentaiboy View Post
    Can’t see no FA
    well spotted however it refers to the OP before the first edit..
  11. #11
    I made a hash of it because I'm not much Apple qualified (and I don't have images on this iPad). Look in the "dohicky" thread for the original Omega order that indicates all but the callotte is "soft iron."
    Bill in Sacramento
  12. #12
    UK
    4,484
    Callie being the dust cap?
  13. #13
    7,272
    Quote Originally Posted by Bill in Sacramento View Post
  14. #14
    UK
    4,484
    Colette sorry. All thimbs, sorry thumbs😊
  15. #15
    7,272
    calotte = cover
  16. #16
    UK
    4,484
    Well good news then, if I can get accurate measurements should be able to produce a calotte from some iron round bar.
  17. #17
    7,272
    perhaps you should start taking orders ? ..
  18. #18
    UK
    4,484
    Have to find a supplier of soft iron bar
    1 1/2 inch first. Not so easy it seems.
  19. #19
    UK
    4,484
    Well it ain't cheap. 40mm (1 1/2 ") @ 400mm round bar is around £150. ARMCO® soft ingot iron. 100mm is £112. So it pays to buy the 400mm length.
  20. #20
    May 2014
    24
    That ring looks almost like the ring that is in CWC watches. Those are made in brass and then nickelplated i think.
