Results 1 to 16 of 16
Thread: Benrus mil-w-46374a Split Crown Stem Replacement?
    Default Benrus mil-w-46374a Split Crown Stem Replacement?
    1975 Benrus mil-w-46374a Split Crown Stem Replacement?
    anyone know where I might obtain?
    thanks! all
    Mark L
    1,702
    Is it the inner half you are after? Or outer half?
    probably both....................watch is with repairer whom is having trouble sourcing part
    crown and attached part of stem will no longer attach to wind/set
    Mark L
    1,702
    Can you ask your watchmaker if the movement is based on the ETA Cal 2372 or 2750?
    There are stems available on eBay. Cousins don't have the inner halves but obviously sell the generic outer half.
    https://www.ebay.co.uk/itm/132105059577
    that's great Roddy.................will get him to check this out
    thanks!
    Mark L
    Senior Member bobsy's Avatar
    Jul 2009
    1,904
    I believe it is based on ETA2750... found this old post
    The Benrus 46374A is fitted with a Benrus GY1L3 P/N 179Q
    This is a non-hacking 7J movement based on the ETA 2750
    yes! it's an ETA2750...plenty of regular stems on eBay but no two part ones
    ...hoping something comes my way................
    Mark L
    1,702
    Some ETA stems will be interchangeable. Let me have a look around.
    1,702
    Select "2750 Male Only":
    https://www.ebay.co.uk/itm/112244252533
    This is the inner section.
    Your watchmaker then needs a female section which they may have lying around (they should do!). They are available here:
    https://www.cousinsuk.com/product/female-swiss-made
    I have some, but can't remember what crown tap size mine are (0.9 or 1.0mm).
    Roddy
  10. #10
    Member maxgara1979's Avatar
    Nov 2012
    Australia
    149
    You can also buy the complete set (male inner part + female outer part ) from John Senior at Obsoletewatchparts. However, he only carries 0.9mm outer parts. If your crown has 1mm thread and you need a female outer part, send me a PM because they are very hard to find and I've a few of them around. Contrary, 1mm male outer parts can be easily purchased from Cousinuk.
  11. #11
    thanks! again ..........however speaking with watch repairer it's not quite as he expected..we
    require 'female' part illustrated? this has corroded at end and part has broken off no longer
    gripping 'male'end from crown
    ideas?
    Mark L
  12. #12
    thanks! for advice
    Mark L
  13. #13
    Nov 2012
    Australia
    149
    Quote Originally Posted by howzabowser View Post
    ideas?
    Mark L
    I've just had the same problem with a Benrus GG-W -113 which has a 17J movement based on the same ebauche. Finding a female stem for the ETA 2750 is virtually impossible. It's much easier to change both parts of the stem using a more common male inner part and female outer part. The complete set from John Senior is about 18 pounds including international postage. Just check with your watchmaker is the crown tread is a common 0.9mm or a more odd 1mm.
  14. #14
    Nov 2012
    Australia
    149
    thanks! all
    Mark L
    Any luck with your stem? By the way, what size was the crown thread?
  15. #15
    thanks! so much got watch back ...............repaired...running good better than + 30 secs /24 hr.......for a mere 5 charge
    bad news min hand has lost a tiny spec of lume...................i guess it's just a cheap watch anyway
    detail of repair..........LOL that's as much as i know.......am gonna divulge
    sorry! no idea of size asked..........
    Mark L
  16. #16
    Nov 2012
    Australia
    149
    Looks good!
    Unfortunately some lume loss has to be expected if you are not super cautious when handling the hands. And, if you really want, they can ca re-lumed later on.
