Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 58
Thread: Blancpain Fifty Fathoms and Hamilton 308 Device
  1. #21
    Member bpc's Avatar
    Feb 2009
    Huntsville, AL
    147
    Quote Originally Posted by BrianDumais View Post
    Have you tired checking with a continuity tester what happens at 2400? Thanks Brian
    I've wondered the same thing...maybe I should put a multimeter on mine and see what happens!
  2. #22
    Very cool. Was it difficult to remove crystal. The stem screw must have been just under the dial. Have you tired checking with a continuity tester what happens at 2400? Thanks Brian
    I had a professional do it. It was more involved than opening the Blancpain. I need to put a crown on it and then see what happens at 24 but haven't tried yet.
  3. #23
    Member hookedseven's Avatar
    Mar 2015
    Brit in Germany
    688
    Thanks for the nice write-up Ashmoret, and as others have said it's great that it has worked out the way it has. I had the feeling from your original thread that you were buying to sell on, but after the time and effort you've put into researching this I think would be great to keep at least one of them (or even better both of them!!)
  4. #24
    Quote Originally Posted by reg-life View Post
    I would like to keep them, and may for a while. But candidly the Blancpain is worth too much for me to wear regularly. I think I will sell it at some point. I'm not sure yet about the Hamilton.
  5. #25
    Senior Member river rat's Avatar
    Jan 2009
    Montana USA
    2,975
    Congrats glad it turned out a happy ending and it was legit
  6. #26
    what an amazing find and story
  7. #27
    Unfortunately it just stopped working. Need to take it in tomorrow and see what's wrong.
  8. #28
    Quote Originally Posted by Ashmoret View Post
    Full movement service is long overdue. If you can live without the watch for 6 months, send it to Jack at International watch works (IWW). He will sort you out and have your watch running properly in no time. Best wishes. Khurram.
  9. #29
    Ashmoret, a truly impressive undertaking with fantastic results.
    Best, Bob.
  10. #30
    Senior Member foilguy's Avatar
    UK
    4,481
    Quote Originally Posted by genghis View Post
    Bit of a oxymoron there khurram 😊
  11. #31
    1,687
    Anyone know how the bomb fuse watch worked? Did you just remove the watch and say goodbye to it when you wanted to use it for triggering explosions?
  12. #32
    Jan 2009
    Montana USA
    2,975
    Probably like a time bomb since the watch the timing device kiss the watch good by when it blows up.
  13. #33
    Member bpc's Avatar
    Feb 2009
    Huntsville, AL
    147
    That was my assumption as well. Set it as a countdown, and when the clock hits 2400, *boom*
    I played around with the multimeter last night and wasn't able to measure any voltage at or near midnight. I'll mess around with it some more and see if I can learn anything else.
  14. #34
    1,687
    Quote Originally Posted by bpc View Post
    I would have expected it to be a contact closure rather than a voltage source.
  15. #35
    Member bpc's Avatar
    Feb 2009
    Huntsville, AL
    147
    Quote Originally Posted by rodabod View Post
    Fair point...would the device being detonated have its own power source for igniting the caps? (Admittedly, I know nothing about ordnance.) Is there a way I could measure a change at 2400? Measure if a circuit is open then closes?
  16. #36
    1,687
    Yes, just measure continuity. Some multimeters will have a beeper setting for closed/short circuit.
    Does it feel a bit odd when you get near 24.00, like you might get blown up?
  17. #37
    Member bpc's Avatar
    Feb 2009
    Huntsville, AL
    147
    Haha, a little! I feel like I'm in a movie...
    No dice on continuity. The multimeter indicated an open circuit at 2400 (and all the way around the rest of the dial - I turned the crown to see if any other time closed the circuit). I haven't opened mine to see if it has the same insides as the OP's.
  18. #38
    1,687
    "Not the black wire!!!! Cut the red!!!!!!"
  19. #39
    Quote Originally Posted by foilguy View Post
    Bit of a oxymoron there khurram ��
    haha! Priming the noob's patience incase he decides to sent the watch to Jack! ��
  20. #40
    I would assume its normal closed circuit?!?
    Brian
